Hi,,, bdr
Thanks for replay.
In this moment I'm having still high ping. But yesterday I changed the omni to sector and I was able to ping from GW to node with 1 ms but from node to gw the ping was still high. Do you have any idea why is this happen..
here is the result of reg..table..
INTERFACE RADIO-NAME MAC-ADDRESS AP SIGNAL-STRENGTH TX-RATE UPTIME
0 5.8Ghz Darling-Ton 00:0B:6B:84:A8:49 no -62dBm@6Mbps 54Mb... 12h53m5s
1 5.8Ghz Bld2210-D 00:0C:42:05:CE:44 no -69dBm@6Mbps 48Mb... 12h53m5s
2 5.8Ghz BLD2090-C 00:0C:42:05:83:84 no -51dBm@36Mbps 54Mb... 12h53m5s
3 5.8Ghz BLD2090-A 00:0C:42:05:CE:4F no -68dBm@6Mbps 36Mb... 12h53m5s
4 5.8Ghz BLD2110-D 00:0C:42:05:11:EB no -52dBm@48Mbps 54Mb... 12h53m5s
5 5.8Ghz Bld-108 00:0C:42:05:CD:E5 no -74dBm@9Mbps 36Mb... 12h53m5s
6 5.8Ghz BLD2140-B 00:0C:42:05:81:B7 no -66dBm@12Mbps 48Mb... 12h53m5s
7 5.8Ghz BLD2200-A 00:0C:42:05:CE:46 no -81dBm@6Mbps 18Mb... 12h53m4s
And you see in 2200bld I have -81 signal and I so close like 200 metters. Why i can't have better signal. I change wireless card pigtail but I didn't changed cable. Can be the cable causing the problem for particular AP.
also here the stats result
0 interface=5.8Ghz radio-name="Darling-Ton" mac-address=00:0B:6B:84:A8:49 ap=no wds=no rx-rate="48Mbps2"
tx-rate="54Mbps2" packets=226735,190137 bytes=242506851,20123837 frames=226735,190137 frame-bytes=241160433,18983015
hw-frames=237427,193922 hw-frame-bytes=257754403,24211725 tx-frames-timed-out=0 uptime=12h55m17s last-activity=700ms
signal-strength=-67dBm@48Mbps signal-to-noise=30dB
strength-at-rates=-60dBm@6Mbps 9s380ms,-63dBm@9Mbps 1h15m28s910ms,-62dBm@12Mbps 40m50s780ms,-62dBm@18Mbps 1m55s330ms,-
62dBm@24Mbps 24s530ms,-65dBm@36Mbps 3s770ms,-67dBm@48Mbps 700ms,-68dBm@54Mbps 44s490ms
tx-signal-strength=-66dBm tx-ccq=87% rx-ccq=56% p-throughput=53366 ack-timeout=25 nstreme=no framing-mode=none
routeros-version="3.6" last-ip=10.84.128.6 802.1x-port-enabled=yes compression=no wmm-enabled=no
1 interface=5.8Ghz radio-name="Bld2210-D" mac-address=00:0C:42:05:CE:44 ap=no wds=no rx-rate="6Mbps2" tx-rate="48Mbps2>
packets=11812409,8729164 bytes=2765732811,1902983569 frames=11812409,8729164 frame-bytes=2694868017,1850608585
hw-frames=12800749,9783669 hw-frame-bytes=4042513387,2530384223 tx-frames-timed-out=0 uptime=12h55m17s
last-activity=0s signal-strength=-69dBm@6Mbps signal-to-noise=28dB
strength-at-rates=-69dBm@6Mbps 0s,-70dBm@9Mbps 35s980ms,-69dBm@12Mbps 42s630ms,-70dBm@18Mbps 42s890ms,-70dBm@24Mbps
42s890ms,-71dBm@36Mbps 44s820ms,-72dBm@48Mbps 44s820ms,-73dBm@54Mbps 7m28s970ms
tx-signal-strength=-68dBm tx-ccq=92% rx-ccq=31% p-throughput=51147 ack-timeout=25 nstreme=no framing-mode=none
routeros-version="3.6" last-ip=10.84.129.199 802.1x-port-enabled=yes compression=no wmm-enabled=no
2 interface=5.8Ghz radio-name="BLD2090-C" mac-address=00:0C:42:05:83:84 ap=no wds=no rx-rate="36Mbps2"
tx-rate="48Mbps2" packets=9608600,11633268 bytes=4080101731,3267657004 frames=9608600,11633268
frame-bytes=4022460205,3197857396 hw-frames=9947403,11633671 hw-frame-bytes=175685187,3477535249
tx-frames-timed-out=0 uptime=12h55m17s last-activity=10ms signal-strength=-53dBm@36Mbps signal-to-noise=44dB
strength-at-rates=-51dBm@6Mbps 9s380ms,-51dBm@9Mbps 12h55m17s350ms,-53dBm@12Mbps 12h55m17s330ms,-53dBm@18Mbps
12h55m17s280ms,-51dBm@24Mbps 1m5s720ms,-53dBm@36Mbps 10ms,-52dBm@48Mbps 400ms,-55dBm@54Mbps 380ms
tx-signal-strength=-47dBm tx-ccq=95% rx-ccq=94% p-throughput=53096 ack-timeout=29 nstreme=no framing-mode=none
routeros-version="3.6" last-ip=10.84.135.238 802.1x-port-enabled=yes compression=no wmm-enabled=no
3 interface=5.8Ghz radio-name="BLD2090-A" mac-address=00:0C:42:05:CE:4F ap=no wds=no rx-rate="6Mbps2" tx-rate="48Mbps2>
packets=11914292,11098042 bytes=3863295381,1874255578 frames=11914292,11098042 frame-bytes=3791820717,1807667326
hw-frames=13314739,11526296 hw-frame-bytes=1006732453,2490983654 tx-frames-timed-out=0 uptime=12h55m17s
last-activity=10ms signal-strength=-70dBm@6Mbps signal-to-noise=27dB
strength-at-rates=-70dBm@6Mbps 20ms,-69dBm@9Mbps 340ms,-70dBm@12Mbps 370ms,-70dBm@18Mbps 590ms,-70dBm@24Mbps 420ms,-
70dBm@36Mbps 420ms,-72dBm@48Mbps 500ms,-74dBm@54Mbps 43s410ms
tx-signal-strength=-69dBm tx-ccq=91% rx-ccq=72% p-throughput=47526 ack-timeout=25 nstreme=no framing-mode=none
routeros-version="3.6" last-ip=10.84.130.154 802.1x-port-enabled=yes compression=no wmm-enabled=no
4 interface=5.8Ghz radio-name="BLD2110-D" mac-address=00:0C:42:05:11:EB ap=no wds=no rx-rate="48Mbps2"
tx-rate="54Mbps2" packets=1157315,884072 bytes=1133759458,112792426 frames=1157315,884072
frame-bytes=1126828984,107487994 hw-frames=1180904,884215 hw-frame-bytes=1180058332,128736929 tx-frames-timed-out=0
uptime=12h55m17s last-activity=10ms signal-strength=-49dBm@36Mbps signal-to-noise=48dB
strength-at-rates=-48dBm@6Mbps 9s380ms,-50dBm@9Mbps 12h55m17s390ms,-51dBm@12Mbps 12h55m17s310ms,-50dBm@18Mbps
12h55m17s220ms,-51dBm@24Mbps 12h55m17s100ms,-49dBm@36Mbps 350ms,-51dBm@48Mbps 10ms,-55dBm@54Mbps
1s390ms
tx-signal-strength=-46dBm tx-ccq=99% rx-ccq=100% p-throughput=54923 ack-timeout=25 nstreme=no framing-mode=none
routeros-version="3.6" last-ip=10.84.128.7 802.1x-port-enabled=yes compression=no wmm-enabled=no
5 interface=5.8Ghz radio-name="Bld-screening" mac-address=00:0C:42:05:CD:E5 ap=no wds=no rx-rate="24Mbps2"
tx-rate="36Mbps2" packets=237061,241292 bytes=31577975,21947238 frames=237061,241292 frame-bytes=30169691,20499486
hw-frames=303174,254016 hw-frame-bytes=49480592,28191494 tx-frames-timed-out=0 uptime=12h55m17s last-activity=600ms
signal-strength=-74dBm@24Mbps signal-to-noise=23dB
strength-at-rates=-75dBm@6Mbps 9s380ms,-74dBm@9Mbps 11s860ms,-74dBm@12Mbps 6s510ms,-74dBm@18Mbps 1s390ms,-74dBm@24Mbps
600ms,-75dBm@36Mbps 4s330ms,-77dBm@48Mbps 1m490ms,-79dBm@54Mbps 4h48m4s160ms
tx-signal-strength=-72dBm tx-ccq=84% rx-ccq=42% p-throughput=41143 ack-timeout=25 nstreme=no framing-mode=none
routeros-version="3.6" last-ip=10.84.131.252 802.1x-port-enabled=yes compression=no wmm-enabled=no
6 interface=5.8Ghz radio-name="BLD2140-B" mac-address=00:0C:42:05:81:B7 ap=no wds=no rx-rate="24Mbps2"
tx-rate="48Mbps2" packets=20334624,20951683 bytes=2309348947,4237426775 frames=20334624,20951683
frame-bytes=2187348475,4111716677 hw-frames=22017682,20962232 hw-frame-bytes=4117264025,334184305
tx-frames-timed-out=0 uptime=12h55m17s last-activity=0s signal-strength=-66dBm@18Mbps signal-to-noise=31dB
strength-at-rates=-65dBm@6Mbps 9s380ms,-66dBm@9Mbps 5s80ms,-66dBm@12Mbps 4s890ms,-66dBm@18Mbps 310ms,-66dBm@24Mbps
50ms,-66dBm@36Mbps 2s920ms,-68dBm@48Mbps 3s990ms,-71dBm@54Mbps 4s90ms
tx-signal-strength=-65dBm tx-ccq=95% rx-ccq=47% p-throughput=51880 ack-timeout=25 nstreme=no framing-mode=none
routeros-version="3.6" last-ip=10.84.132.230 802.1x-port-enabled=yes compression=no wmm-enabled=no
7 interface=5.8Ghz radio-name="BLD2200-A" mac-address=00:0C:42:05:CE:46 ap=no wds=no rx-rate="6Mbps2" tx-rate="18Mbps2>
packets=14068298,14695215 bytes=592679369,3375468051 frames=14068298,14695215 frame-bytes=508277897,3287296761
hw-frames=16446138,14695254 hw-frame-bytes=2607477296,3639983281 tx-frames-timed-out=0 uptime=12h55m16s
last-activity=10ms signal-strength=-81dBm@6Mbps signal-to-noise=16dB
strength-at-rates=-81dBm@6Mbps 30ms,-81dBm@9Mbps 22s870ms,-81dBm@12Mbps 2m12s860ms,-81dBm@18Mbps 2m18s20ms,-
81dBm@24Mbps 2m18s20ms,-82dBm@36Mbps 2m18s220ms
tx-signal-strength=-82dBm tx-ccq=69% rx-ccq=29% p-throughput=26329 ack-timeout=25 nstreme=no framing-mode=none
routeros-version="3.7" last-ip=10.84.137.216 802.1x-port-enabled=yes compression=no wmm-enabled=no
Any idea why some AP has low rx-ccq is problem on GW or in node .
Please any idea man will help me alot.
thx selim .
