Bandwith & Redundancy
I have 2 questions:
  • what maximum bandwith I can filtering and queuing with router PC P4 2.8Ghz 1GB Ram. I have 200+ users who use 3Mbits each. Maximum peak already is 55-60 Mbits. Can I Use mikrotik in this situation.
  • is there posible to use 2 Router PC’s in redundancy configuration. Do you try to make something for this options in your RouterOS.
Thanks in Advance.
you can do even more, don’t worry. we have tested 3Gbps throughput with a 2.8Ghz Xeon computer and some intel gigabit interfaces.
This sounds good about bandwith.
And what you can say about redundancy at this time?
VRRP. http://www.mikrotik.com/docs/ros/2.9/ip/vrrp
