bandwith shaping and squid cache
is there any possibilty to disable shaping from the cached objects in the squid inside mikrotik ? it means if pppoe user requested any already downloaded file he can get it with full speed lan
thanks
Hi, in this example you can do that: http://www.mikrotik.com/docs/ros/2.8/root/queue.content#6.54.7.4
thanks for ur kind reply
but as i understood fromt he example i will not be able then to shape the clients , the example now shape the outgoing interface of the router
