I have done a bandwidth test between two Router Board 750 GL (ROUTER OS 6.7) during 60 seconds. I have checked that a lot of packets have been lost during the test but when the test is finished it shows Lost packets=0. Why it does not show the total packet lost?
The problem is not the pipe because I have connect with a straight cable. I am working in my desk before going to the customer. The problem is that packets have been lost during the band with test but when the test is finished it shows 0 PACKETS. Why it does not show all the packets that have been lost during the test?
How are you proving that packets are lost?
You are pushing 40Mbps through a 1,000Mbps pipe, direct connected. I would be surprised if you were losing packets at all. You are testing UDP, but you are NOT pushing 110% of the pipe, so you shouldn’t see any dropped packets at all.
It is very easy to drop packets because I remove the Ethernet cable during 3 seconds aprox. and once I connect it again the packet lost it shows 10.000 packes lost (for example), and when the test finishs it shows 0 packet LOST, how is it posible it shows 0 packe lost if during the test it has been lost 10.000 packets as mínimum.
