Bandwith test
Does anybody know why the bandwith test is unsupported in the newest Os Router versions?
How to resume such feature?
Any suggestion?
Thanks you.
Regards,
Antonella
Bandwidth is supported in new version.
We added new feature for bandwidth test, when you can specify TCP connection number for bandwidth test, when you want to get more accurate results.
Perhaps, you are sending bandwidth test from new device to old or vice versa by TCP, set TCP connection=1 when you have such setup.
