# Bare metal CHR on Hetzner Dedicated
**URL:** <https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885>\
**Category:** General\
**Created:** [August 31, 2018, 5:20pm UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885 "2018-08-31T17:20:10Z")\
**Posts on this page:** 10\
**Page:** 1
<div class="post-metadata">
**Author:** ![Joni](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/joni/32/1485_2.png) [@Joni](https://forum.mikrotik.com/u/Joni)\
**Post date:** [August 31, 2018, 5:20pm UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/1 "2018-08-31T17:20:10Z")
</div>
> [@CHR on OVH VPS SSD](https://forum.mikrotik.com/t/chr-on-ovh-vps-ssd/107670/1):
> ```plaintext
> cd /root && curl -O https://download2.mikrotik.com/routeros/6.42.3/chr-6.42.3.img.zip && gunzip -S .zip chr-6.42.3.img.zip
> dd if=/root/chr-6.42.3.img of=/dev/sda
Tried this on Hetzner dedicated (bare metal, EX series, I know bm isn’t officially supported but I don’t want the virtualization maintenance overhead) however everything except routing (public ip subnets, ie forwarding) works, at least I can’t get it working with any config. Sort of sad. (neither 6.40.9 (Bugfix only) or 6.42.7 (Current) or 6.43rc66 (Release candidate))
> Please open a new topic and describe what exactly does not work. It’s either working completely or not. It cannot ‘disable routing for some unknown reason’. Where do you get your “public subnets”? Can’t Hetzner block unknown IPs by default (it should, I hope)?
Either working completely or not was my impression too, until I tried this.
The intention is to provide public IP addresses to another mikrotik router behind NAT over L2TP VPN, via EoIP (nevermind overhead). L2TP works _(if assigned to can internally ping each other with the public subnet IPs)_, EoIP _(if assigned to can internally ping each other with the public subnet IPs)_ works but traffic from internet to the public subnet doesn’t even enter Ether1-WAN (or anywhere else for that matter, torch).
Hetzner provides public IPs / subnet upon order [https://wiki.hetzner.de/index.php/Zusaetzliche\_IP-Adressen/en#Subnets](https://wiki.hetzner.de/index.php/Zusaetzliche_IP-Adressen/en#Subnets) and trying any combination of “every” mikrotik forum suggested way of getting them forwarded, as in routing, doesn’t work. “Obviously” the server doesn’t have internal physical interfaces (uncertain if nor why it should matter). Hetzner support has verified the public subnet (/29) is routed to the public WAN IP. There are no firewalls etc, just plain routing. ([https://wiki.mikrotik.com/wiki/Simple\_Static\_Routes\_Example](https://wiki.mikrotik.com/wiki/Simple_Static_Routes_Example) etc)
@Chupaka I’m happy to provide you (reputation) with the RouterOS logins / details to the “empty” test installation if you care to test it yourself, as I surely have exhausted all theories on why it shouldn’t work.
**Post date:** [September 1, 2018, 5:37am UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/2 "2018-09-01T05:37:39Z")
</div>
To be specific, even assigning a one additional IP to the ether1-WAN interface doesn’t respond to ping, with Linux it works without anything more than
```plaintext
ip address add a.b.c.d/32 dev eth0
**Post date:** [September 1, 2018, 7:51am UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/3 "2018-09-01T07:51:24Z")
</div>
Exact same issue [http://forum.mikrotik.com/t/multiple-public-subnets/103645/1](http://forum.mikrotik.com/t/multiple-public-subnets/103645/1)
and almost same, except I can’t ping out… [http://forum.mikrotik.com/t/two-public-ip-on-wan-interface/75455/1](http://forum.mikrotik.com/t/two-public-ip-on-wan-interface/75455/1)
**Author:** ![Chupaka](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/chupaka/32/215_2.png) [@Chupaka](https://forum.mikrotik.com/u/Chupaka)\
**Post date:** [September 3, 2018, 9:46am UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/4 "2018-09-03T09:46:34Z")
</div>
Ping me at Skype
**Author:** ![izumin](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/izumin/32/2000_2.png) [@izumin](https://forum.mikrotik.com/u/izumin)\
**Post date:** [October 25, 2019, 4:05pm UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/5 "2019-10-25T16:05:41Z")
</div>
Did you anyhow solve the problem?
**Post date:** [October 26, 2019, 3:40pm UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/6 "2019-10-26T15:40:20Z")
</div>
Unfortunately no.
**Post date:** [October 31, 2019, 10:27am UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/7 "2019-10-31T10:27:28Z")
</div>
its a pity, i have the same problem. Just move with my CHR to hetzner and there is no route(s) that can make it be online. But neighbor VM’s is pinging but no hypervisor.
**Post date:** [October 31, 2019, 4:14pm UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/8 "2019-10-31T16:14:47Z")
</div>
Duh… Forgot to mention that Hetzner Cloud works for CHR…
**Author:** ![normis](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/normis/32/8_2.png) [@normis](https://forum.mikrotik.com/u/normis)\
**Post date:** [November 1, 2019, 8:39am UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/9 "2019-11-01T08:39:28Z")
</div>
Yes, Hetzner Cloud works fine like this: [https://wiki.mikrotik.com/wiki/Manual:CHR\_Hetzner](https://wiki.mikrotik.com/wiki/Manual:CHR_Hetzner)
**Author:** ![aniston](https://forum.mikrotik.com/letter_avatar/aniston/32/6_449c533f586939b6e5f246632a46421f.png) [@aniston](https://forum.mikrotik.com/u/aniston)\
**Post date:** [December 11, 2020, 9:47am UTC](https://forum.mikrotik.com/t/bare-metal-chr-on-hetzner-dedicated/122885/10 "2020-12-11T09:47:12Z")
</div>
Not sure if this is related , but i managed to get the CHR 7.1B3 running on Hetzner vCloud as per the quick and simple doc at [https://wiki.mikrotik.com/wiki/Manual:CHR\_Hetzner](https://wiki.mikrotik.com/wiki/Manual:CHR_Hetzner).
That was fast and to the point, but after adding a private network and connecting it to the CHR I still could not activate it under IP \> Addresses in WinBox although in the configuration I can select ether2 as the Interface , in the terminal I get that the Interface ether2 is invalid
```plaintext
 ip address/print
Flags: I - INVALID, D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
  # ADDRESS NETWORK INTERF
  0 I 192.168.1.2/24 192.168.1.0 ether2
  1 D a.b.c.d/32 172.31.1.1 ether1
under Interfaces i see that there is no link, in the Hetzner rescue system I can see the Inteface is present as
```plaintext
 ip -a
shows me eth0 and eth1 present.
Basically I’m Trying to use the CHR as a simple WAN/LAN Firewall and expose only certain resources from another Hetzner vCloud server which is coupled internally to the LAN ether2 interface , so how do we get the second Interface up and available on a CHR in Hetzner vCloud , is this possible ?
