Hello ppl
I think this will be my final question and thank you all for being very helpfull
I have assigned a task
to setup a wifi on a campus which is 600meters long and 200 metes wide
It has 2 rows of concrit buildings on 2 line shape
Im really confused on what equipment should i use
Im thinking of setting up 2 base stations which will have
435 Routerboard with 4 r52nm mini pci cards
3 sectors at 2,4 GHz 8dbi dual coplarization and 1 panel 14 dbi at 5Ghz (which it will connect to the other basestation)
Sectors are these http://linkshop.gr/shop/wi-fi/antenna-2.4ghz/sectors/interline-sector-dual-8dbi-2.4ghz.html
Panel are these http://linkshop.gr/shop/wi-fi/antenna-5ghz/panels-el/interline-panel-14dbi-5ghz.html
I dont know if it will cover the hole place
Any suggestions for sector antennas ?
any other tested configuration ?
i will upload a “map” soon to
