I trying to install a base unit based on:
- 3 X 120deg 16dbi dual (H/V) MIMO antennas (2.4GHz) (360deg total)
- 2 X 4 way antennas splitter
- Ubinquity SR71-12 miniPCI card
- RB433AH
I need help to get it installed, the main question is which is the best configuration?
my idea is, each antenna has two N-TYPE Outputs (V and H), I am thinking in connecting the V outputs of the 3 antennas to one splitter and the V outputs to another splitter which I will get one cable from V splitter and another from H splitter. each cable will be connected to each chain in Ubinquity SR71-12 miniPCI card. anybody has another solution?
Which polarization should I use for TX and RX, V or H?
