Hello everyone!
I have a BaseBox2 which due to corrosion has some broken pins in the ethernet port. Unfortunately the pins that broke are the ones responsible for the power over ethernet. Anyway, I removed it and I’d like to replace it now with a new one, but I’m not sure as to the type of the ethernet port that is used in this PCB.
Can someone shed some light as to what type of replacement part (ethernet port) I should be looking so I can track it from either mouser or farnell ?
Thanks in advance,
P.S : Looks like this one : https://export.farnell.com/amp-te-connectivity/1-406541-5/modular-jack-tht-r-a-rj45-8p8c/dp/2059750?st=ethernet%20port
