Hi friends,
Can I use 3G internet with Bsebox 2 sim slot ?
sure.
That’s not depending on the SIM-Slot ![]()
That pretty much depends on the provider service available on the SIM card (=> consult with your provider) and the type of miniPCIe-card you’re going to use (=> consult supported hardware matrix
greets
