Basebox 2 tx power and speed issues
Hi everyone!!
I buy a basebox 2 and on the spec’s say it has tx power of 30dbm (1000 mw) and speed of 300mbps, so as usually when i buy somenthing i expect at least what is advertised right??
But only show on the current tx power: 27dbm and on the inSSIDer speed of 150mbps, i already try to change the tx power, leaving the Tx power mode on Default so it run at the max but still on Current Tx power 27dbm.
So im wrong or there is a magic way to get the advertised??
Thank you in advance
Hi! Have you figure it out, same problem here
