Just 30 clients per cell !!! Then I’m going to need many cells for 100+ users!
Basebox has a gigabit interface, hope it will be useful in serving the heavy bandwidth demands of the clients.
The system can handle more than 30 users /cell (i’m not sure if 100 connected radio can download in the same time…).
As i said, the problem on the bandwidth side, and not on number of clients.
If you sell only 512kbps, it’s no problem. If you sell 5mbps average, with 10mbps burst, and 10 of 50 users are using it in the same time (on the same sector) you need to be able to push 50mbps downstream (plus ~10-20mbps upstream). I think, you will need 40mhz for this (since not all (if any) client will go with optimal radio communication).
(keep in mind, in P2P, 40mhz, MIMO you can push ~200mbps TCP data. 20Mhz a little bit less than half. and still optimal radio environment, highly focused high gain antenna, good radios. You will want to spend much less than this for client side, so you will go for SXT - and ofcourse that will not give the same quality for you)
Thinking like above, if you want to serve 100 nearby customers with 50mbps aggregated - go for a single omni.
If you want to give 3x50mbps aggregated - than go for 3x120deg sectors. that will give bigger coverage too.
If you need more bandwidth / cell, and/or bigger coverage, split up again to 4x90 or 6x60. That will give 4x50 (200mbps) or 6x50 (300mbps) site thruput.
You also have to feed this site - so go for licenced or 24ghz or fiber uplink.
If some clients are bigger distance than average, use 60cm MIMO dish antennas (for example with 912 board).
Keep in mind, if a client has low signal, it can take off airtime from the others!!!
(i mean, if most clients can go with 48mbps and some can go with 12mbps, until the slow can download 1mbyte, the faster could download 4mbyte - but cannot, since airtime used up)
