basebox, incorect voltage/temp display
I have a new relay that is a netmetal 5 and a basebox 5
basebox reports voltage: 13.9V temperature: 30C
netmetal reports voltage: 14.5V temperature: 12C
This is a common temp relay setup till we decide if we like the position and will build
there or move down a bit. 20ft ethernet and passive poe injectors at the bottom. At
the top these 2 radios. Checked the cables and they look fine, swapped them, same
reported V/T. I checked my other baseboxes and the others look with in a acceptable
margin.
