we have a basebox5 with 90° sector of 21 dBi. In the basebox we have 35 clients, that are 33 SXT 5HnD and 2 Sextant, the nearest is 500 meters, the farthest is a sextant at 10Km.
All works ok, until yesterday, at certain times of the day, always different, we lose a lot of ping from the clients to the basebox. No ping lost if a client try to ping an other client. No ping lost if from the backbone i am trying to ping the basebox from LAN.
What do you think about this?
Thanks!
normis
July 21, 2014, 10:06am
2
Hello campa4bt
Please post your full config, so we can see if there is no problem there. Thanks
This is the basebox:
# jan/03/1970 18:53:34 by RouterOS 6.15
# software id = 78W3-MWTN
add admin-mac=4C:5E:0C:4C:19:92 auto-mac=no l2mtu=1600 name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=20 band=5ghz-a/n channel-width=\
20/40mhz-ht-above country=italy disabled=no frequency=5700 \
ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-rxchains=0,1 ht-txchains=0,1 \
l2mtu=2290 max-station-count=50 mode=ap-bridge nv2-preshared-key=\
Password1x nv2-security=enabled ssid=SUD wireless-protocol=nv2-nstreme
/interface wireless nstreme
set wlan1 enable-nstreme=yes
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=Password1x
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
add bridge=bridge-local interface=ether1
add bridge=bridge-local interface=wlan1
add address=10.10.0.11/16 comment="default configuration" interface=\
bridge-local network=10.10.0.0
set allow-remote-requests=yes servers=10.10.0.1,8.8.8.8
/ip dns static
add address=192.168.88.1 name=router
add distance=1 gateway=10.10.0.1
/ip upnp
set allow-disable-external-interface=no
/system identity
set name="PONTE SUD"
/system leds
set 0 interface=wlan1
/system routerboard settings
set cpu-frequency=600MHz
And this is one of the SXT connected:
# jan/03/1970 04:31:10 by RouterOS 6.15
# software id = 0I7N-WQDG
add l2mtu=1598 name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-ht-above \
country=italy disabled=no frequency=5700 ht-ampdu-priorities=1 l2mtu=2290 \
mode=station-bridge name=wlan1-gateway nv2-preshared-key=Password1x \
nv2-security=enabled radio-name="Bagni 51" ssid=SUD wireless-protocol=\
nv2-nstreme
set [ find default-name=ether1 ] name=ether1-local
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=Password1x \
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add address-pool=default-dhcp interface=ether1-local name=default
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add bridge=bridge1 interface=ether1-local
add bridge=bridge1 interface=wlan1-gateway
add address=10.10.1.51/16 comment="default configuration" interface=\
ether1-local network=10.10.0.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
bridge1
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1
/ip dns static
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=\
wlan1-gateway
add chain=forward comment="default configuration" connection-state=\
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" disabled=\
yes out-interface=wlan1-gateway
/ip service
set api disabled=yes
/ip upnp
/system identity
set name="BAGNI 51"
/system leds
add interface=wlan1-gateway leds=led1,led2,led3,led4,led5 type=\
wireless-signal-strength
add interface=ether1-local leds=user-led type=interface-activity
/tool mac-server
/tool mac-server mac-winbox
Thanks a lot.
/interface wireless
/ip dns static
/ip upnp
/system identity
/system leds
And this is one of the SXT client connected:
/interface wireless
nv2-nstreme
/ip ipsec proposal
/ip dhcp-client
bridge1
/ip dns static
wlan1-gateway
established
/ip service
/ip upnp
/system identity
set name="BAGNI 51"
/system leds
/tool mac-server
