Basebox5 - NO PPP intervafe
Hello Guys,
i need some help.
Last week i bought a Basebox 5 (RB912UAG-5HPnD-OUT), one of my client.
I could set up everything, except the SIM card.
I have a 3G card inside (yes, the card are correctly way inside), but there is no LTE interface, and there is no interface on the PPP client connection box.
I have nothing... nada..
Here is the export:
_[meszaba@UNI_GSM.rbcl] /interface lte> export
apr/24/2017 08:37:22 by RouterOS 6.38.5
software id = 2S0J-RXSN\
_
I also copied the LTE package, in case...
_[meszaba@UNI_GSM.rbcl] /system package> print
Flags: X - disabled
NAME VERSION SCHEDULED
0 routeros-mipsbe 6.38.5
1 system 6.38.5
2 X ipv6 6.38.5
3 wireless 6.38.5
4 hotspot 6.38.5
5 dhcp 6.38.5
6 mpls 6.38.5
7 routing 6.38.5
8 ppp 6.38.5
9 security 6.38.5
10 advanced-tools 6.38.5
11 lte 6.38.5_
Have u got any clue?
Basebox5 is, basically, a case with a generic RB912UAG board inside. It has SIM-card slot, but it does not have the actual 3G or LTE modem hardware installed. It just has a miniPCIe slot on board. You have to chose a suitable compatible modem and install it into that miniPCIe slot in order to make use of this SIM-card slot.
He already said it has one installed…
Thank you for your replies, it’s solved.
We have to change the Basebox 5 to SXT-LTE.
