The hEX is connected to the internet with default configuration and a dhcp-server running on it.
I did reset (No Default Configuration) the cAP, enabled a bridge, attached the ether/wifi interfaces to it and enabled the wifi interfaces with appropriated security profiles.
So far so good, its working.
I would like to create a guest VLAN but i am not sure how to do it.
Should i create a Interface->VLAN and Wireless->Virtual Interace at the cAP?
Then do i have to create a DHCP Server for this VLAN on the cAP as well?
If anyone got a good tutorial or can help me with some commands, would appreciate it.
The wifi-type is Wifi Wave2.
