Basic config internet access issues
First time with a Mikrotik and not a network wiz so I apologize in advance. I’m configuring a CRS310 for homelab and everything was working when I was behind my existing UNIFI router. When I simply move the WAN port to the starlink router directly I start to encounter issues. I can still ping just fine and everything I tried is reachable however web browsing is extremely slow, pages partially load, or I get a “PR_END_OF_FILE_ERROR” message.
reading other posts I adjusted the MTU down to 1400 even though pings with a size of 1500 worked fine. I finally blew it away and used the Quick Set button and the results are exactly the same.
I can keep my PC plugged into ether2 and move ether1 from the starlink to the UNIFI and everything will instantly start working. Starlink gives out a 192.168.1.X IP to the Mikrotik and UNIFI gives out a 192.168.100.X IP if this matters for any reason. When daisy chained through the UNIFI a fast.com speed test is showing 120mb down, 10mb up, and 30ms loaded which is normal for my location.
Any help with troubleshooting would be greatly appreciated.
Here is the current config
# 1970-01-02 00:29:27 by RouterOS 7.15.3
# software id =
# model = CRS310-8G+2S+
# serial number =
add admin-mac= auto-mac=no comment=defconf name=bridge
add name=WAN
add name=LAN
add bridge=bridge comment=defconf disabled=yes interface=ether1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add interface=ether1 list=WAN
add interface=bridge list=LAN
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
/ip dhcp-client
set servers=8.8.8.8
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os
## Here is what I had when testing the MTU but is removed in current
set [ find default-name=ether1 ] l2mtu=1492 mtu=1400
set [ find default-name=ether2 ] l2mtu=1492 mtu=1400
set [ find default-name=ether3 ] l2mtu=1492 mtu=1400
set [ find default-name=ether4 ] l2mtu=1492 mtu=1400
set [ find default-name=ether5 ] l2mtu=1492 mtu=1400
set [ find default-name=ether6 ] l2mtu=1492 mtu=1400
set [ find default-name=ether7 ] l2mtu=1492 mtu=1400
set [ find default-name=ether8 ] l2mtu=1492 mtu=1400
set [ find default-name=sfp-sfpplus1 ] l2mtu=1492 mtu=1400
set [ find default-name=sfp-sfpplus2 ] l2mtu=1492 mtu=1400
