Im having some trouble trying to understand the mikrotik…
I have created a route in the Watchguard to reach the 10.0.0.0/30 network…ut im not able to ping/winbox the Mikrotik with the IP 10.0.0.2/30
I attached the diagram…
Nevermind i got it…its working now
with the info you provided and the way i understand it I can only tell: add bride to both devices and and under bridge-ports put interfaces in that bridge.
for example if you are connecting 2 RB433 trough eth2 on both of them then add bridge1 to both devices and put eth2 in that bridge again on both devices.
