Basic Configuring
Good Afternoon
Does someone have an example for a simple routing configuring MicroTik as a basic gateway? I mean a local subnet 10.0.0.0/24 conectes through MTK to public network 200.190.60.91/8.
Regards
You might want to go thru this
http://www.mikrotik.com/docs/ros/2.8/guide/basic
or this
How to Link Public Addresses to the Local Ones?
http://www.mikrotik.com/docs/ros/2.8/howto/howto
If the still did not get it on the links above, say so and I will give you vivde example if you give me your detail.
Paul
