Basic Homeassistant setup behind Mikrotic
Hi.
I’m struggling with my firewall NAT config to achieve what I’ve got in my mind. I got a little knowladge of networking, but I guess it’s not enough.
I’ve got running homeassistant server running on my local network on static 192.168.13.246 and it’s accessable over LAN (+hairpin is working well). So basically from local I can reach it with my public, local or aliased (homeassistant) over port 8123. That’s great.
The problem is when I try to get there from outside of my local network - can’t reach it at all and there isn’t any package going through.
My current firewall NAT is looking like this:
Flags: X - disabled, I - invalid; D - dynamic
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
 1    chain=srcnat action=masquerade protocol=tcp src-address=192.168.13.0/24 dst-address=192.168.13.246 out-interface=bridge dst-port=8123 log=no log-prefix=""
 2    chain=dstnat action=dst-nat to-addresses=192.168.13.246 to-ports=8123 protocol=tcp dst-address=!192.168.13.1 in-interface=bridge dst-port=8123 log=no log-prefix=""
but I probably tired few dozens tweaks and for now I’m not sure if I understand what I am doing -.-
/export file=anynameyouwish ( minus router serial number and any public WANIP info )
That’s what I’ve got. Strangely there was not one mention about my public IP o0
# feb/08/2023 00:36:43 by RouterOS 7.7
# software id = Z6H2-0GD9
# model = RBD52G-5HacD2HnD
# serial number = ???
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=Musztarda wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=Musztarda5G wireless-protocol=\
    802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.13.10-192.168.13.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.13.1/24 comment=defconf interface=bridge network=\
    192.168.13.0
/ip arp
add address=192.168.13.246 interface=bridge mac-address=YY:YY:YY:YY:YY:YY
/ip dhcp-client
add address=192.168.13.0/24 comment=defconf dns-server=192.168.13.1 gateway=\
    192.168.13.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.13.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat dst-address=192.168.13.246 dst-port=8123 \
    out-interface=bridge protocol=tcp src-address=192.168.13.0/24
add action=dst-nat chain=dstnat dst-address=!192.168.13.1 dst-port=8123 \
    in-interface=bridge protocol=tcp to-addresses=192.168.13.246 to-ports=\
    8123
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Warsaw
/tool mac-server
/tool mac-server mac-winbox
(1) Change this rule
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
TO:
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment=“drop all else”
(2) Modify your source nat rules so they are like so…
add action=masquerade chain=srcnat dst-address=192.168.13.0/24 src-address=192.168.13.0/24
add action=masquerade chain=srcnat comment=“defconf: masquerade”
(3) Finally change your DST NAT ADDRESS two options since its not clear.
A. if you have a fixed WANIP address (static), then:
add chain=dstnat action=dst-nat dst-address=WAN_fixed_IP dst-port=8123 protocol=tcp to-address=192.168.13.246
B. if you have a dynamic WANIP, can and does change, then:
add chain=dstnat action=dst-nat dst-address-list=MYWANIP dst-port=8123 protocol=tcp to-address=192.168.13.246
where the firewall address list called MYWANIP is
add ip-address=mynetnameIPCLOUD list=MYWANIP.
C. Another option for dynamic you could use but most prefer B…
add chain=dstnat action=dst-nat dst-address-type=local dst-address=!192.168.13.1 dst-port=8123 protocol=tcp to-address=192.168.13.246
but that only works with a one subnet Structure, if you have multiple subnets you would have to put them on a firewall address list…
Still the same:
    invalid
    connection-state=new disabled=yes in-interface-list=WAN
add action=accept chain=forward comment="internet traffic" in-interface-list=\
add action=accept chain=forward comment="port forwarding" \
add action=drop chain=forward comment="drop all else"
add action=masquerade chain=srcnat dst-address=192.168.13.0/24 src-address=\
    192.168.13.0/24
add action=dst-nat chain=dstnat dst-address=x.x.x.x dst-port=8123 log=\
    yes log-prefix=---dst-nat protocol=tcp to-addresses=192.168.13.246
It looks ok from my local network, but outside service can’t be reached =/
Is your Mikrotik device behind another router?
Gosh, yea -.-
forgot about that trauma.. but AFAIK there is made port forwarding there or even DMZ set on Mikrotik IP.
You didnt change your firewall rules as suggested, so I dont expect it to work.
If your not willing to try stuff to fix your problem why are you here ???
When and if you do and if still doesn’t work then the issue is not MT, and ensure you have port forwarded correctly from the main router.
It should be port forwarded to the WANIP of the MT router ( its LANIP on the main router subnet ).
IF that doesnt fix it then there are still a few things to consider, is the ISP is blocking the traffic.
Perhaps also check the server, sometimes they have built in firewalls that can block traffic, or even the PC firewall if the server is behind a PC.
“AFAIK”?? Well, you’d better double check it then, just to rule it out.
I’m not sure what do you mean.. I basically did what you suggested, just checked with diff checker:
(1) I disabled mentioned rule instead of deleting, yea - I didn’t know it makes a difference, it still shouldn’t apply, am I wrong? I also added three rules you wrote.
(2) all source nat rules are the same you wrote
(3) since I’ve got static IP from provider I did option A and added one dst rule feeding it with my WAN IP (and added logging, but I can’t see how it will effect anything).
I don’t know what I’ve missed there. Sorry if it looked like I just ignored your suggestion, but I don’t know what I did wrong there =/
Sorry I didn’t clear it out - I was at work and didn’t have access to my network (I should’ve clarify that). Router that is accessing Internet is from ISP, so it has limited functionality I can change, but after double checking I had my 8123 port forwarded and DMZ was set to my HA IP.
EDIT: I’ve figured it out. Thanks for that config and pointing out that there’s another router in the middle. Turns out I just needed to point dst-address in dst-nat to my MT ip in subnet created by my ISP router.
