basic hot spot without authentication and external login web
Hi guys.
This is what I want to achieve.
Set a hotspot service on my box.
Users should be forwarded to captive portal.
I want them just fill some basic form (name , email , ) no password requiered.
Then they should be able to access to internet.
Question is:
What authentication method should I use ? (wifi ap is setted to open)
I would like to use an external php login page , so , what should it return , so mikrotik will know that registration is ok ?
Regards.
Leandro.
Hi leostereo
May be these link can help you.
I tried to achieve the same function with Node JS + Express JS, but it is still not working now.
http://cotswoldpc.blogspot.com/p/mikrotik-routerboard-rb750up-simple.html
https://wiki.mikrotik.com/wiki/HotSpot_external_login_page
Hi , I have some improvements … contact me.
