basic ICMP rule
Good evening,
I have problem that router rb4011ias having 2 lans, bridge and VoIP-Bridge at ip 192.168.100.1/24 and 192.168.0.1/24 and i have internet on both lan but
i can not ping my router but ping google etc on either lan with ip from respective bridge. i see that my router does not responde to ping from internet as well so secure but i think
ICMP/ping is vital to have a efficient network.
tried adding chain=input, protocol=icmp, accion=accept but lan ping still does not work, tried disable windows firewall but no succes not hits in firewall rule that i places as number 1.
basically what is the icmp rule that should make the router respond to icmp from any pc in any lan network ?
Thank you
It pings out of the box, so you’ve configured the capability away somehow. Post your sanitized configuration here and we can help you debug it.
I suspect your ISP provider is blocking ICMP on the WAN side but as stated, its all hot air, or letters until you post your config!
you where correct, had to fight with ISP before it started to work
I don’t see how you can blame the ISP when “lan ping still does not work,” but success, I guess?
did a reset and programed again and you are probably right eventually but it works.
Thank you
