Basic ip addressing use and bridge setup
Martin - you might try posting in the Switch OS forum…
I have two of these and they are in a production environment so I don’t want to fool w/them. Ordering some new ones in the new year, just don’t have one on hand at the moment…
Thom
Hi Thom,
Following the data specs of the CRS226-24G-2S+ the unit is using routerOS not switchOS.
regards
martin
A CRS without wireless with the default config will have all ports switched and the master-port should be ether1, not ether2. A default IP address of 192.168.88.1 should also be assigned to ether1, but no dhcp, etc.
http://wiki.mikrotik.com/wiki/Manual:Default_Configurations
Check the master-port settings from
/interface ethernet export
and set your ip and dhcp server accordingly.
