Basic ip addressing use and bridge setup
I have a CRS226-24G-2S+ and am trying to setup a simple bridge or vlan for two ports with dhcp and gateway ip address.
Am more used to Cisco then mikrotik.
my config so far is
add name=BR-10
add name=default-dhcp ranges=172.16.10.5-172.16.10.10
add add-arp=yes address-pool=default-dhcp always-broadcast=yes disabled=no interface=BR-10 lease-time=3d name=default
add bridge=BR-10 interface=ether2
add bridge=BR-10 interface=ether3
add address=172.16.10.1/24 interface=BR-10 network=172.16.10.0
/lcd interface pages
set 1 interfaces=ether13,ether14,ether15,ether16,ether17,ether18,ether19,ether20,ether21
add address=172.16.10.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=172.16.10.1
When I connect my macbook on ether2 it does not get an ip address, and when i set it with fixed ip address it also cannot ping 172.16.10.1
I posted the above first in routerOS section, but was told to do it in this section due to the model used.
Any feedback what i am doing wrong config wise ?
martin
Try posting in the Beginner Basics or General forums. This forum is only for SwOS devices, and the CRS is ROS.
