RB750Gr2, 5 independent ethernet ports, WAN1 - WAN2 (PCC load) , LAN3 10.10.10.1 (10.10.10.0/29) , LAN5 192.168.0.1 (192.168.0.0/24)
Default routes for each segment, each LAN is correctly natted outside.
ISSUE → I can’t ping from 10.10.10.3 to 192.168.0.100 (whereas i can from 10.10.10.3 to 192.168.0.1)
Last firewall rule is DROP ALL
Tried to implement a forward rule for LAN3 and LAN5 but no luck (rule is placed at the top of the FW list)
Any suggestion? I feel like i’m missing a stupid thing
traffic is mangled to route packets correctly (if a packet goes outside / comes from WAN1 is marked accordingly and further packets are sent from that interface)
But this is the part which works perfectly, no LAN to WAN issues, only LAN to LAN
