basic nat masquerade
i have a problem with basic nat rule :confused:
this is my configuration:
add mtu=1500 name=lan_bridge
add mtu=1500 name=wan_bridge
/interface wireless
set [ find default-name=wlan1 ] l2mtu=2290
/system logging action
set 1 disk-file-name=log
set 2 remember=yes
set 3 src-address=0.0.0.0
add bridge=wan_bridge interface=ether1
add bridge=wan_bridge interface=ether2
add bridge=lan_bridge interface=ether3
add bridge=lan_bridge interface=ether4
add bridge=lan_bridge interface=ether5
add address=192.168.233.1/24 interface=ether1 network=192.168.233.0
add address=192.168.2.1/24 interface=lan_bridge network=192.168.2.0
add action=masquerade chain=srcnat fragment=no out-interface=wan_bridge
src-address-type=“”
/ip ipsec policy
set (unknown) dst-address=0.0.0.0/0 src-address=0.0.0.0/0
add distance=1 gateway=192.168.233.199
/ip upnp
set allow-disable-external-interface=no
/snmp
set trap-community=public
The problem is when attach file in gmail (or other email). after few second the upload stop and i have error “unable to attach”
if i upload in wan_bridge port (ex 2) i don’t have any problem… i think that the problem is in masquerade action.
Have any suggestion?
Move address from ether1 to wan_bridge.
Thanks Jarda…but not resolve the problem…
well,
then change the masquerade rule as follows:
add action=masquerade chain=srcnat out-interface=wan_bridge to-addresses=0.0.0.0
You can also try to get rid of wan_bridge, set the ether1 as wan and make ether2 as its slave. In this case of course everything that is set to wan_bridge should be moved to ether1.
