I’m having problems setting up a simple port forwarding from my public IP interface to an internal private IP.
I’m trying to forward the port 3306 (MySQL) to the internal IP 192.168.73.109:3306.
Because I was unable to do it, I also tested forwarding the port 8080 to 192.168.73.109:80.
There shouldn’t be anything else required, just the nat rule, without requiring a filter rule to accept it (which, btw, I tried too).
If I scan the ports from the outside it only show the service ports as opened, everything else is closed.
Any clue will be appreciated.
This is the export of the simple rules I have so far.
- Note: I have an IPSec tunnel going from 192.168.73.0/24 to 192.168.44.0/24, that’s the only rule you’re going to see there.
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=log chain=input disabled=no dst-port=8080 in-interface=pppoe-arnet \
log-prefix=HTTP protocol=tcp
add action=accept chain=input disabled=no dst-port=8080 in-interface=\
pppoe-arnet protocol=tcp
add action=accept chain=input disabled=no src-address=192.168.44.0/24
add action=accept chain=input comment="default configuration" disabled=no \
protocol=icmp
add action=accept chain=input comment="default configuration" \
connection-state=established disabled=no
add action=drop chain=input comment="default configuration" disabled=no \
in-interface=ether1-gateway
add action=dst-nat chain=dst-nat disabled=no dst-address-type=local dst-port=\
8080 in-interface=pppoe-arnet protocol=tcp to-addresses=192.168.73.109 \
to-ports=80
add action=log chain=dst-nat disabled=no dst-address-type=local dst-port=3306 \
in-interface=pppoe-arnet log-prefix="MYSQL NAT" protocol=tcp
3306 in-interface=pppoe-arnet protocol=tcp to-addresses=192.168.73.109
add action=accept chain=srcnat disabled=no dst-address=192.168.44.0/24 \
src-address=192.168.73.0/24
add action=masquerade chain=srcnat comment="default configuration" disabled=\
no out-interface=pppoe-arnet
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
