Basic QoS rules needed - can't seem to configure it
Hi there,
I’ve been trying to setup QoS on my RB800 using the wiki guides (following ToS guides) but after playing around with it alittle I found that ToS isn’t really what I need.
Basically I’m trying to setup QoS for (highest first)
1)VOIP
2)HTTP/HTTPS
3)Media (videos)
4)Other
I feel the only way to really get this working is to use port based QoS - but I’m stuck on creating rules to do this for the whole network due to my setup.
Eth1 - WAN (for LAN 192.168.0.X)
Eth2 - WAN (for LAN 192.168.1.X)
Eth3 - Bridge >>> Netgear Switch (LANs)
WLAN - part of 192.168.0.X
Could someone kindly point me in the right direction to get to setup - ideally an example rule of how I would allow apply a rule which could cover both LANs and WANs.
Thank you.
mine look like this
GTS is my PPPoE connection to the internet. Recommend to make the diagram not to loose the overview of what you want to acheive.
rgs
/ip firewall mangle
add action=mark-packet chain=prerouting comment=“” disabled=no dst-port=53 new-packet-mark=High_Priority passthrough=
no protocol=udp
add action=mark-connection chain=prerouting comment=“UDP / Games Martin” disabled=no new-connection-mark=UPDandGames
passthrough=yes protocol=udp src-address=192.168.xxx.xxx
add action=mark-packet chain=prerouting comment=“” connection-mark=UPDandGames disabled=no new-packet-mark=
High_Priority passthrough=no
add action=mark-connection chain=prerouting comment=VOIP disabled=no new-connection-mark=VOIP passthrough=yes
src-address=192.168.0.xxx
add action=mark-packet chain=prerouting comment=“” connection-mark=VOIP disabled=no new-packet-mark=High_Priority
passthrough=no
add action=mark-connection chain=prerouting comment=“Winbox connection” disabled=no dst-port=8291
new-connection-mark=winbox-conn passthrough=yes protocol=tcp src-address=192.168.0.0/24
add action=mark-packet chain=prerouting comment=“” connection-mark=winbox-conn disabled=no new-packet-mark=
add action=mark-connection chain=forward comment=“Dreambox server” disabled=no dst-address=192.168.0.xxx
new-connection-mark=DB out-interface=LAN1_Master passthrough=yes
add action=mark-packet chain=prerouting comment=“” connection-mark=DB disabled=no new-packet-mark=High_Priority
passthrough=no
add action=mark-connection chain=prerouting comment=“Terminator HTTP Traffic” disabled=no dst-port=80
new-connection-mark=Terminator-http-conn passthrough=yes protocol=tcp src-address=192.168.0.xxx
add action=mark-packet chain=prerouting comment=“” connection-mark=Terminator-http-conn disabled=no new-packet-mark=
Terminator_Medium passthrough=no
add action=mark-connection chain=prerouting comment=“Terminator low priority Traffic” disabled=no
new-connection-mark=Terminator-Low-conn passthrough=yes protocol=tcp src-address=192.168.0.xxx src-port=
1024-53000
add action=mark-packet chain=prerouting comment=“” connection-mark=Terminator-Low-conn disabled=no new-packet-mark=
add action=mark-connection chain=prerouting comment=“Other PCs HTTP Traffic” disabled=no dst-port=80
new-connection-mark=OtherPCs-conn passthrough=yes protocol=tcp src-address=192.168.0.0/24
add action=mark-packet chain=prerouting comment=“” connection-mark=OtherPCs-conn disabled=no new-packet-mark=
Other_Medium passthrough=no
add action=mark-connection chain=prerouting comment=“Other PCs low priority Traffic” disabled=no new-connection-mark=
Other-Low-Conn passthrough=yes protocol=tcp src-address=192.168.0.0/24 src-port=1024-53000
add action=mark-packet chain=prerouting comment=“” connection-mark=Other-Low-Conn disabled=no new-packet-mark=
Other_Low passthrough=no
add action=mark-connection chain=prerouting comment=Pilgrim disabled=yes new-connection-mark=OtherPCs-conn
passthrough=yes src-address=192.168.0.0/24
add action=mark-packet chain=prerouting comment=“” connection-mark=Pilgrim-conn disabled=yes new-packet-mark=Pilgrim
passthrough=no
[admin@MikroTik] /ip firewall mangle>
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=512k name=Total_Upload
packet-mark=“” parent=GTS priority=1
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=180k max-limit=512k name=UL_Terminator
packet-mark=“” parent=Total_Upload priority=4
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=4M name=Total_Download
packet-mark=“” parent=LAN1_Master priority=1
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=128k max-limit=512k name=UL_High packet-mark=
High_Priority parent=Total_Upload priority=1 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=1500k max-limit=4M name=DL_Terminator
packet-mark=“” parent=Total_Download priority=3
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=1500k max-limit=4M name=DL_Other packet-mark=
“” parent=Total_Download priority=4
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=1M max-limit=4M name=DL_OtherMedium
packet-mark=Other_Medium parent=DL_Other priority=4 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=500k max-limit=4M name=DL_OtherLow
packet-mark=Other_Low parent=DL_Other priority=8 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=1M max-limit=4M name=DL_TerminatorMedium
packet-mark=Terminator_Medium parent=DL_Terminator priority=3 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=500k max-limit=4M name=DL_TerminatorLow
packet-mark=Terminator_Low parent=DL_Terminator priority=6 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=160k max-limit=512k name=UL_TerminatorMedium
packet-mark=Terminator_Medium parent=UL_Terminator priority=4 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=20k max-limit=512k name=UL_TerminatorLow
packet-mark=Terminator_Low parent=UL_Terminator priority=6 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=180k max-limit=512k name=UL_Other packet-mark=
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=20k max-limit=512k name=UL_OtherLow
packet-mark=Other_Low parent=UL_Other priority=8 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=160k max-limit=512k name=UL_OtherMedium
packet-mark=Other_Medium parent=UL_Other priority=4 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=250k max-limit=4M name=DL_High packet-mark=
High_Priority parent=Total_Download priority=1 queue=default
[admin@MikroTik] /queue tree>
A good start on understanding HTB for QoS in mikrotik
http://tiktube.com/index.php?video=253
