Basic QoS
I want some basic QoS on RouterOS.
I can explain this on Cisco CLI.
Please help me translate this to RouterOS CLI.
# ip access-list extended LIST1
       permit ip 192.168.0.0 0.0.0.255 host 192.168.120.215
#class-map MATCH_LIST1
       match access-group LIST1
#policy-map PRIORITY_LIST1
       class  MATCH_LIST1
           bandwidth 2048
# int f0/0
      description To_branch1
      service-policy output  PRIORITY_LIST1
p/s RouterOS 6.7 (6.10)
In MikroTik it is configured under “Firewall->Mangle” and “Queing”.
Add a rule under Firewall->mangle/postrouting that marks your traffic with a user-chosen mark
and under queueing add a queue that matches this mark and limits the rate.
I can’t see “Queing” under “Firewal” settings.
The Queuse is under main menu.
Is it right? (see
screenshot)
You need to use firewall mangle rules to identify the traffic that you want to apply QoS to.
Create an address list for the hosts you want to limit
/IP firewall address-list add address=192.168.1.0/24 list=limit
Then create the firewall rules to mark the connections and use the connection mark to mark packets for that connection
/ip firewall mangle
add action=mark-connection chain=forward dst-address-list=limit new-connection-mark=limit-connection
add action=mark-packet chain=forward connection-mark=limit-connection dst-address-list=limit new-packet-mark=limit-packet passthrough=no
Then create a simple queue with the limits you need.
/queue simple
add limit-at=0/2M max-limit=0/2M name=2mblimit packet-marks=limit-packet target=""
Ade
