Basic questions for configuring DMZ in small network with mikrotik
Hi, basically im still a beginner in mikrotik world, i want to ask:
My senior in office need help to re-configure our network management using mikrotik (RB-1100) and he asked me to research about DMZ.
so as far as i read about DMZ on the internet, the thing should be done to configure the DMZ is NAT-ing.
i am here to ask to you all, is there anything else that i have to do with the configuration on mikrotik for DMZ?
is anyone can help to tell me what kind of filtering rule and route-list that needed for configuring it.?
any answer will be helped.
thanks before.
First of all you need to consider for yourself, what you want to achieve with DMZ.
MikroTik RouterOS does not have such checkbox DMZ=enabled/disabled.
But MikroTik RouterOS provides you with wide range of firewall/NAT/mangle features, that allows to achieve any possible setup with firewall.
