Basic roaming scenario
Hi!
I need help with following configuration:
dhcp+router ↔ ethernet_wifi_vlan ↔ mikrotik rb600 APs
Each RB600 has 2 mPCI cards. I want to create a wireless network with transparent client roaming using this hardware. I mean, that all 4 cards in 2 rb600 should provide the same wireless network and allow clients to switch between APs transparently. How can I configure mikrotiks to make it work (using wired ethernet vlan as APs backbone)?
Thanks in advance :slight_smile:
Use the same SSID and bridge all your AP’s
