I’m trying to set my Routerboard 523 in such a manner that all traffic from the wireless network will be routed to the wired network and vice versa. No NAT needed !!
Please tell me how to configure this to work correctly
what IP address ranges are in use?
ok. 192.168.200.0/25 - network address
192.168.200.127 - broadcast address
255.255.255.128 - subnet mask
192.168.200.1 - DHCP, DNS Server
192.168.200.2 - Gateway
192.168.200.7 - Routerboard IP Address
THANK YOU FOR ANY ASSISTANCE
cornflicks@hotmail.com
are both the wired and wireless networks in the 192.168.200 range?
yup. I found a solution. I bridged the wlan and lan interfaces using Mikrotik’s Webbox. Took a while to uncover that simple feature. Thanks for the help though
