Basic Routing
Hi All,
This is what I've setup:
PC1[10.10.10.1/30] ------[10.10.10.2/30----192.168.0.1/30]---------[192.168.0.2/30]PC2
PC1 : g/w 10.10.10.2
PC2: g/w 192.168.0.1
Print from CLI
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADC 10.10.10.0/30 10.10.10.1 ether8 0
1 ADC 192.168.0.0/30 192.168.0.2 ether1 0
ADDRESS NETWORK INTERFACE
0 192.168.0.2/30 192.168.0.0 ether1
1 10.10.10.1/30 10.10.10.0 ether8
I still can't ping end to end. Any help is appreciated.
The configuration seems correct. Possibly it’s a firewall problem: on PC1, on PC2 or on the router.
based on your picture, I assume that [10.10.10.2/30----192.168.0.1/30] are two ports on the same router, specifically ether8 and ether1
Two potential problems:
1)
Why are you putting the addresses of the PCs on your router? You should put 10.10.10.2 and 192.168.0.1
  1. Did you set up a SRCNAT (masq) between ether 1 and ether 8?
