anscs
1
Hi everyone,
I’m using Mikrotik ver 3.4
My script is:
:for e from 5 to 25 do={
/queue simple add name=("IP-" . $e) \
target-addresses=(172.16.10. . $e) \
max-limit=32000/64000
after execution on Winbox Terminal
[admin@Mikrotik] > :for e from 5 to 25 do={
{... /queue simple add name=("IP-" . $e) \
{\... target-addresses=(172.16.10. . $e) \
{\... max-limit=32000/64000
interrupted
value of target-address must contain '/'
[admin@Mikrotik] >
what’s wrong?
if execution on Winbox Terminal with Mikrotik ver 2.9.50 … no problem.
thanks
| m | a | m | a | n |
Letni
2
V3.4 had some scripting bugs so you should upgrade to 3.6.
Also one major change in V3 is you need to have quotes around your values. So change max-limit=32000/64000 to max-limit=“32000/64000” and try again.
-Louis
anscs
3
Dear Louis,
I’m already upgrade from 3.4 to 3.6
but the same as problem
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 3.6 (c) 1999-2008 http://www.mikrotik.com/
[admin@Mikrotik] >
{\... max-limit="32000/64000"
interrupted
[admin@Mikrotik] >
anscs
4
Problem is solve
just type script like
target-addresses=("172.16.10." . $e . "/32") \
Thanks for Louis
| m | a | m | a | n |
