Basic SCSI Support
Ok… I know you guys aren’t interested in it, but given that you are pursuing Virtualization, sooner or later you will have to support BusLogic or LSI Logic controllers. Your software has to be able to run on those big, honking machines that provide the horsepower for 10 operating systems on the same computer, and RouterOS has to have some sort of SCSI device emulation to offer up to your guest operating systems.
I know that is a lot of work, but for now, just take a simple step for us -
Check the option for LSI or BusLogic support in the next Kernel build.
Thanks!
Indeed, it would be nice to use routerOS as the router for an ESX system (vpn tunnels to remote datacenters without the servers ever having to touch a physical lan would be great)
