I just got my RouterBOARD 600 with 2 wireless cards and am trying to set it up as simple as I can, in order to quickly replace my current Router (a SGS 440R that really is needs to be changed out).
What I want, just to get things running, is this.
WAN getting IP via DHCP (Working).
1 Wireless Network that also works as a DHCP server, giving out 192.168.0.X addresses (Working).
1 Ethernet Port working as a DHCP server. giving out 192.168.1.X addresses (cannot get this to work).
The thing is, I can get Eth2 setup as a DHCP server giving out IP addresses correctly, but I don’t get any internet access when connecting via this interface. My NAT is setup quite simply as masquerade and it works just fine for the Wireless network.
If you need me to post any settings then please let me know which windows I should screenshot, I’m using WinBOX to do the configuration.
I would really appreciate any assistance I can get, this is driving me nuts and im sure I just missed some small step.
Thanks!
