Basic setup of CCR-1009-8G-1S router
Hi all,
One of my client bought the above router. Not a big job; just have one internet line from an ISP. need to connect this line into one of 8 RJ45 ports this router has. and need to configure another RJ45 port to connect the LAN switch to distribute DHCP.
I also need to configure the basic hotspot on this LAN facing port.
I was trying all the previous tutorials, but this router is too much to do this job. Can somebody describe how can I achieve this task, step by step?
Cheers!
Have you read http://wiki.mikrotik.com/wiki/Manual:Initial_Configuration ?
“First RouterOS version: ccr1009” :slight_smile:
if you think is too many work to do, hire a consultant to do that
