Dear All,
Please help me. I am new to Mikrotik. I just bought Mikrotik Router RB1200 I want to start using it. The following is my senario
I have a point to point link from the ISP and through that I have to route my other global IPs and all the computers that will be connected should get Internet connection, two ports should do NAT.
Apart from that I also have another link from different ISP (Backup link) When the primary link go down this should take up.
Please help me on what I can do. Step by step instructions if possible.
Add simple NAT (chain: src-nat, action: masquerade)
Then add in IP > Routes, two default gateways, but change distance (eg. primary link Distance: 1, secondary link Distance: 10).
When primary gateway is unreachable, routerboard will automaticaly use gateway with distance 10, until primary is reachable again…
