I’m new to Mikrotik… I have a RB1200 in lab to play with. I’m trying to setup what could become an ethernet demark using the switchip features.
I’m stuck right at the beginning tryning to do a simple vlan task: Getting vlan 100 tagged (trunk) on port ether1 to port ether3 untagged (access).
Here’s some stripped print commands:
[admin@MikroTik] /interface ethernet switch> /int eth print
Flags: X - disabled, R - running, S - slave
NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
7 RS ether3 1500 00:0C:42:C0:AA:5D enabled ether1 switch1
9 R ether1 1500 00:0C:42:C0:AA:5F enabled none switch1
[admin@MikroTik] /interface ethernet switch> vlan print det
0 switch=switch1 vlan-id=100 ports=ether1
1 switch=switch1 vlan-id=0 ports=ether3
[admin@MikroTik] /interface ethernet switch> port print det
Flags: I - invalid
2 name=ether3 switch=switch1 vlan-mode=secure vlan-header=always-strip
4 name=ether1 switch=switch1 vlan-mode=secure vlan-header=add-if-missing
[admin@MikroTik] /interface ethernet switch> rule print det
0 switch=switch1 ports=ether1 vlan-header=present vlan-id=100 copy-to-cpu=no redirect-to-cpu=no mirror=no new-dst-ports=ether3
1 switch=switch1 ports=ether3 vlan-header=not-present copy-to-cpu=no redirect-to-cpu=no mirror=no new-vlan-id=100
It looks pretty much like the example in the switchchip feature wiki… What am I missing ?
Thanks for any help.
DOuellet
