basic VLAN routing
I’m trying to achieve something that I have thought to be quite basic but unfortunately I’m might missing something.
I have my router with the ether1 the interface connected to the WAN. the interface 4 (ether4) is connected to another router. For this scenario we can forget about this other router.
What I’m trying to achieve is to create a VLAN on the ether6 having vlan-id 170 which would give internet connection to any devices connected.
At the moment with the configuration i have set the machines connected to the ether6 get IP address but nothing else. they cannot ping any external address and they cannot ping neither the gateway. NAT rule are in place. firewall rules set they should not prevent anything. I’m pretty sure that coming from different vendors I’m assuming something that for Mikrotik works in a different way.
The current configuration should help here.
# 2024-08-11 19:17:06 by RouterOS 7.15.2
# software id = QZSS-FYTG
# model = RB5009UPr+S+
# serial number = [redacted]
add admin-mac=[redacted] auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short vlan-filtering=yes
set [ find default-name=ether1 ] poe-out=off
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] poe-out=off
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface 6to4
add comment="Hurricane Electric IPv6 Tunnel Broker" !keepalive local-address=\
    [redacted] mtu=1280 name=sit1 remote-address=[redacted]
/interface vlan
add interface=bridge name=openmetallab-management-vlan170 vlan-id=170
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLAN
add name=openmetallab-management-vlan170-ip-pool ranges=\
    192.168.170.5-192.168.170.14
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool=openmetallab-management-vlan170-ip-pool interface=\
    openmetallab-management-vlan170 name=openmetallab-management-vlan170-dhcp
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=\
    10 path-cost=10
add bridge=bridge interface=ether6 pvid=170
set udp-timeout=10s
/interface bridge vlan
add bridge=bridge tagged=bridge untagged=ether6 vlan-ids=170
add interface=openmetallab-management-vlan170 list=VLAN
    192.168.88.0
add address=192.168.170.0/28 interface=openmetallab-management-vlan170 \
    network=192.168.170.0
/ip dhcp-client
    192.168.88.1
add address=192.168.170.0/28 dns-server=192.168.170.1 domain=\
    mgmt.openmetal.lab.home gateway=192.168.170.1
set allow-remote-requests=yes cache-max-ttl=1d servers=192.168.170.1
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
    ipsec-policy=in,ipsec
add action=accept chain=forward comment="VLAN Internet Access only" \
    connection-state=new in-interface-list=VLAN out-interface-list=WAN
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 route
add disabled=no distance=1 dst-address=[redacted] gateway=[redacted] \
    scope=30 target-scope=10
add disabled=no distance=1 dst-address=2001:470:5811:1::/64 gateway=\
    [redacted] routing-table=main suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=22222
set winbox disabled=yes
/ip ssh
set strong-crypto=yes
/ipv6 address
add address=[redacted] advertise=no interface=sit1
add address=[redacted] interface=bridge
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/snmp
set enabled=yes trap-version=3
/system clock
set time-zone-name=Europe/Prague
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool graphing interface
add interface=sit1
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=sit1 filter-ip-protocol=icmpv6
I think this address is causing you problems:
It should be 192.168.170.1/28
Indeed it worked. What a typo there. Thanks a lot for checking my config
