Basic Vlan setup on RB750hex and RB750
Hi, I’m a noob to mikrotik technology and networking in general. I have a situation where I need to setup a RB750hex as a router and 2 x RB750’s as management switches in different physical locations. I want to setup a VLAN topology with the RB750’s as management switches connecting to the RB750hex with 2 Trunk ports.
I will have 4 VLANS with ID’s respectively setup as VLANID: 20 = Office (10.10.20.0/24), 30 = Hotspot (10.10.30.0/24), 40 = CCTV (10.10.40.0/24), 50 = Home (10.10.50.0/24)
All VLAN devices should get their IP addresses via the DHCP server which will reside on RB750hex.
I have tried so many times, but just cannot manage to get it working.
Your help in this will be greatly appreciated.
Kind Regards,
theolex82
post your hexconfig so far
/export hide-sensitive file=myconfig
Like anav said, post your config or else we are guessing.. With that said, you said “the DHCP server”. You need to configure a separate DHCP pool and server per VLAN. What you are doing with the RB750 (the one playing router) is somewhat similar to what I am doing with mine. Each of mine has one WAN port, three ports that each carry one VLAN (untagged), and one trunk port that has four or five tagged VALNs. I am not doing any switching in the routers.
