basic web proxy question
I’m trying to figure out if this can work, or if I’m trying to do something that isn’t supported.
I’m trying to make the mikrotik box redirect to a master proxy or to a proxy that is not located on the firewall.
I can not figure out from the manual if this is possible.
Thanks in advance.
Use Parent Proxy, you have to set ip and port of the parent proxy in web proxy…
