The clients are just laptop computers. Connecting maybe 100 ft away in different rooms.
Here is a dump of current client info as you can see client 0 has a tx rate of 36mbps while the other two have only 1mbps
0 interface=wlan1 mac-address=00:24:2C:9D:6F:69 ap=no wds=no bridge=no
rx-rate=“36.0Mbps” tx-rate=“36.0Mbps” packets=9515,8598
bytes=7724106,1899734 frames=9515,8598 frame-bytes=7668240,1848146
hw-frames=12642,9834 hw-frame-bytes=10264856,2084162 tx-frames-timed-out=0
uptime=1h36m1s last-activity=14s100ms signal-strength=-74dBm@1Mbps
signal-to-noise=25dB signal-strength-ch0=-74dBm
strength-at-rates=-74dBm@1Mbps 20s790ms,-68dBm@2Mbps 20s810ms,-
77dBm@5.5Mbps 2m34s530ms,-72dBm@11Mbps 50s40ms,-71dBm@12Mbps
19s570ms,-72dBm@18Mbps 20s230ms,-71dBm@24Mbps 16s540ms,-
70dBm@36Mbps 14s100ms,-72dBm@48Mbps 20s,-72dBm@54Mbps
54s300ms
tx-ccq=84% p-throughput=23038 distance=1 last-ip=192.168.11.41
802.1x-port-enabled=yes management-protection=no wmm-enabled=no
1 interface=wlan1 mac-address=04:54:53:B6:BE:8D ap=no wds=no bridge=no
rx-rate=“24.0Mbps” tx-rate=“1.0Mbps” packets=85,41 bytes=2017,5759
frames=85,41 frame-bytes=1915,5513 hw-frames=7628,217
hw-frame-bytes=245383,10721 tx-frames-timed-out=0 uptime=24m23s
last-activity=4s540ms signal-strength=-62dBm@1Mbps signal-to-noise=37dB
signal-strength-ch0=-62dBm
strength-at-rates=-62dBm@1Mbps 24m23s40ms,-69dBm@2Mbps 19m44s580ms,-
62dBm@11Mbps 9m50s410ms,-64dBm@18Mbps 4m2s200ms,-
65dBm@24Mbps 7m17s550ms,-62dBm@36Mbps 4m1s130ms,-
64dBm@48Mbps 48s60ms,-63dBm@54Mbps 25s730ms
tx-ccq=11% p-throughput=106 distance=1 last-ip=192.168.11.104
2 interface=wlan1 mac-address=CC:F9:E8:C1:A0:F9 ap=no wds=no bridge=no
rx-rate=“54.0Mbps” tx-rate=“1.0Mbps” packets=48,10 bytes=904,644
frames=48,10 frame-bytes=844,584 hw-frames=194,24 hw-frame-bytes=6898,1160
tx-frames-timed-out=0 uptime=13m17s last-activity=9s350ms
signal-strength=-67dBm@1Mbps signal-to-noise=32dB
signal-strength-ch0=-67dBm
strength-at-rates=-67dBm@1Mbps 9s350ms,-78dBm@24Mbps 9m5s230ms,-
79dBm@36Mbps 1m51s880ms,-64dBm@54Mbps 1m29s950ms
tx-ccq=24% p-throughput=952 distance=10 last-ip=192.168.11.88
