Here is a script for a very basic parser, it returns everything in a string found between two strings.
If you need to parse some simple XML or name:value pairs, this should be helpful
It has three parameters:
inputString: The string to search (haystack)
betweenStart,betweenEnd: Return everything from inputString bwteen the end of betweenStart and the start of betweenEnd
If betweenStart is not found in inputString, it will return from the start of inputString
If betweenEnd is not found in inputString, it will return until the end of inputString
:local getBetween do={
# This is a basic parser, can be used for XML
# It takes three parameters:
# inputString - The main string
# betweenStart - Text AFTER this point will be returned
# betweenEnd - Text BEFORE this point will be returned
:local posStart 0;
:if ([:len $betweenStart] > 0) do={
:set posStart [:find $inputString $betweenStart]
:if ([:len $posStart] = 0) do={
:set posStart 0
} else={
:set posStart ($posStart + [:len $betweenStart])
:local posEnd 9999;
:if ([:len $betweenEnd] > 0) do={
:set posEnd [:find $inputString $betweenEnd];
:if ([:len $posEnd] = 0) do={ :set posEnd 9999 }
:local result [:pick $inputString $posStart $posEnd];
:return $result;
Examples:
: put [$getBetween inputString="<element>value</element>" betweenStart="<element>" betweenEnd="</element>"]);
Result: value
: put [$getBetween inputString="<element>value</element>" betweenStart="something" betweenEnd="</element>"]);
Result: <element>value
: put [$getBetween inputString="<element>value</element>" betweenStart="something" betweenEnd="something"]);
Result: <element>value</element>
I’ll be putting more useful scripts on github: https://github.com/StereotypicalSquirrel
