I have a few mangle rules in which I am marking connections and they are working. Currently, those markings are exclusive. By that, I mean the connections are either marked one way or another.
But I now have a need to mark the same connection with another connection mark and I don’t think that will work because I will be destroying later processing.
What is the process regarding multiple connection marking?
Can a connection mark get changed from one value to another? How does one handle the need to mark a connection with two marks? Would you create a new rule for both criteria (the existing and the new) and mark it differently, then split those two later in the rules?
Thank you.
