Is it possible to batch set the type of all LEDs in one line or command string?
Pseudo-example:
/system leds set [find where leds=XXX] type=off
Can the above work and what would XXX be to set all LEDs regardless of names?
Pseudo-example:
I think that you’re trying to disable all leds with one command, and if yes, you can use:
/system leds disable [find]
Thank you!
/system leds set [find] type=off
worked for me. Thank you for the inspiration.
