I would like to know if Mikrotik makes Battery operated APs. I am looking to buy something like a dual band 11ac/11n AP, but want it to be battery operated. Looking for something that will run about 20hrs at least of battery when fully active.
Regards,
Sudarsan.
Almost any mikrotik can be run from batteries. Depending on cable length 24V is the way to go.
What do you need? Is some kind of portable setup?
There are several small units that are powered by USB. You could easily mate one of these with a battery pack used to recharge a cell phone.
