BCM 5721 Drivers
I see you have support for Broadcom BCM4401 nic’s. Is there any chance of you adding support for the BCM5721? It would be the only feature request I would have.
I assume this is gig Ethernet or so. If you can send us your supout file (sent to supout@mikrotik.com).
We will put it on this list or try to add it quicker…
John
This is what I got when I sent it to supout@mikrotik.com — so I sent it to support@mikrotik.com
----- The following addresses had permanent fatal errors -----
<supout@mikrotik.com>
(reason: 550 Bad RCPTS)
----- Transcript of session follows -----
… while talking to mailgw.mikrotik.com.:
RCPT To:<supout@mikrotik.com>
<<< 550 Bad RCPTS
550 5.1.1 <supout@mikrotik.com>… User unknown
Final-Recipient: RFC822; supout@mikrotik.com
Action: failed
Status: 5.1.1
Remote-MTA: DNS; mailgw.mikrotik.com
Diagnostic-Code: SMTP; 550 Bad RCPTS
Last-Attempt-Date: Fri, 29 Jul 2005 08:57:51 -0400
john mistyped the address. correct was support, we received it.
