BCP Bridge - Problem with browsing the Web
Hi gents,
I need a bit of help with a new BCP bridge that I’m working on.
The tunnel is already setup using ROS 3.3, and can ping the local and remote IPs as well as to any site on the Web. Also, as far as I know all traffic generated on the local side is routed through the bridge.
The local side connectivity (3Mbpsx3Mbps) is provided by the cable company and the remote side is a Data Center (100Mbpsx100Mbps).
Now, the problem that I have is that any Web browsing I do is very, very slow.
I have asked my friend Google as well as searched the forums but have not been able to find an answer. So, I would appreciate any pointers to related info and/or suggestions that you may have.
I can ping by IP and domain name. I played with the MTU but had no success improving the browsing.
By the way, I did follow MikroTik’s documentation on how to setup the link.
Let me know if you need any more info.
Thanks & best regards,
-moya
