be careful use the "ip firewall connections"with
:smiley: when more than 150 clients pc online in your lan nerwork ,be careful use the "ip firewall connections"with winbox !!!
because while you do it ,the routeros will too busy to death !!! you must reboot it . i try again!! the same happened!! :exclamation: :exclamation:
now i suggest you be careful !!! :smiley:
I receive a time out also via telnet
why don’t limit teh connection amount?
would you mind posting an example of what you mean? and the settings
well on the forward chain put a drop on the p2p connetcion an connection limit at 150 on tcp connections
don’t you have problems with p2p customers ?
yes there are some that do this!
is this what you mean in those rules? I’ve used smaller numbers though
[admin@MtBures] ip firewall rule forward> print
0 flow=p2p_down limit-count=20 action=passthrough
1 flow=p2p_up limit-count=10 action=passthrough
marked the flow with Mangle as I use this for bandwidth shaping.
well
you should put also protocol=tcp and limit-connection=150 per each user using p2p
we are maybe in teh same case, we have 150 users over the mikortik with just 1 public IP address
is your network using p2p ? doeas it work fine?
